Will 15" Kosei K1 wheels clear the Type R brake conversion?
Old Mar 22, 2018 | 06:03 AM
masospaghetti's Avatar
Default Will 15" Kosei K1 wheels clear the Type R brake conversion?
I did some searching and it sounds like it will but I want to verify before I buy a wheel+tire combination from Tirerack and have it NOT FIT. I was considering both the Kosei K1 and K5R in 15x7.
I have a 98 GSR with the "big brake" conversion (Type R calipers, Mini rotors, TSX pads). I assume this would be exactly the same clearance as an actual Type R.
I really wanted the 15" Enkei RPF1 but those will definitely not fit.
Old Mar 23, 2018 | 02:33 PM
halfakneegrow's Avatar
Default Re: Will 15" Kosei K1 wheels clear the Type R brake conversion?
I have the same brake set up with 949 wheels and I have to run a 3mm spacer to clear the caliper bracket.
Old Sep 8, 2022 | 04:30 PM
mattkosem's Avatar
Sorry for the necro bump but I was also having trouble finding confirmation on this. I can confirm that ET38 15x7 Kosei K1 do fit over the TypeR Caliper/Mini Rotor setup without any issues.
--Matt
jvtec95
Dec 2, 2006 06:34 PM
allmotorslut
Apr 12, 2006 08:00 PM
hondaeg95
Jan 11, 2004 04:23 PM
Live-Spork.HB
Dec 17, 2003 01:17 PM
ek_david
Jul 3, 2003 08:01 AM
