Wet and dry lay ups
Old Mar 19, 2018 | 05:57 AM
harry64's Avatar
Default Wet and dry lay ups
What is the difference in appearance between a wet lay-up and a dry lay-up when they are finished?
Old Mar 21, 2018 | 09:58 PM
RC000E's Avatar
Default Re: Wet and dry lay ups
I don't know that the question is really worded properly. If you mean dry, as in pre-preg which is vac bagged and autoclaved, then it's got a generally thinner (for a given weave), more uniform and flat/dull appearance. Wet layup has an excess of resin, is thicker/heavier (for a given weave), less uniform but will take on the surface of the mold it's in and be shiny/glossy. Either can be clear coated though and have a very clean appearance.
Old Mar 25, 2018 | 10:07 AM
harry64's Avatar
Thanks for the reply, i was also unsure at the question which is why i wanted to ask it. Does it make any more sense if i asked, 'What are the different cosmetic finishes between a wet and dry lay-up?'
Old Apr 24, 2018 | 10:40 PM
Dallasb84's Avatar
there is no difference depending on how you do it and depending on what process you choose.
wet lay up an vacuum bag is ok.... usually will get pin holes on the surface
pre preg will also give you pin holes.
face coat or in mold clear/ gel coat will give any process a perfect finish.
B18CivicEH2
Paint and Body
Apr 25, 2007 10:18 AM
sixfiveoh
Apr 20, 2006 09:41 PM
