97 ex accord h22 swap
I have an 97 ex accord with an h22a swap. The car ran great but not it cranks and won't start . Do far I've changed the tps sensor, throttle body, spark plugs, an fuse relay still cranks but not starting I have spark and smell gas. So it is getting gas.
could it be the injectors are bad, fuel pump, the main fuel sending unit . Really need help I don't want to get rid of the car
Okay this might sound a bit stupid and I can be totally embarrassing myself, but this happened to my car(was getting spark, it was getting gas and everything great..engine just wasn't turning over to start). I fought with that for 2 days..the ONLY thing that fixed this was pushing hard on the brake and pumping wildly on the accelerator while turning the ignition. It roared to life! Let me know what works for you..
I don't think it's mechanical timing due to the fact that it's cranking it might be the crankshaft that's either disconnected or not set properly and if it does come down to the timing and then I hope I don't need a timing belt kit
projektt
Jan 20, 2009 02:16 AM
