Want to Buy Want to Trade/Want to Buy
40/40 prop valve and lines for ABS delete on 94 LS Integra
Old Mar 17, 2018 | 06:40 PM
Mike457's Avatar
Default 40/40 prop valve and lines for ABS delete on 94 LS Integra
I have a 94 LS Integra. The ABS system has gone dead (which is common apparently) and I'd like to remove the ABS system altogether. My mechanic told me I need to find the 40/40 prop valve and lines for the job. Does anybody on here have a set for sale or know where I can get it? Please respond with pics and asking price. Thanks!
Old Apr 24, 2018 | 04:43 AM
Chrisfrom1986's Avatar
Default Re: 40/40 prop valve and lines for ABS delete on 94 LS Integra
Go to the junkyard and get the lines yourself out of an RS or any non abs civic. The prop valve from a DA Integra will work but will only bolt to 1 of 2 firewall studs (no big deal). You will also need a non abs brake master cylinder as the fittings are in different locations for non abs and are a different size. I also used a DA 15/16ths master cylinder (same as RS non abs DC). Do your own research.
Old Apr 24, 2018 | 12:17 PM
simjosh's Avatar
I got prop valve and front brake lines from MC to prop to wheels *95 RS Teg*
Don't have the rear... that's something you maybe able to bend into place?
Old Apr 24, 2018 | 07:17 PM
He'll need the RS master to go with it. The rear lines might be able to be bent.
Old Apr 25, 2018 | 12:39 AM
simjosh's Avatar
https://honda-tech.com/forums/sale-1...ooler-3318878/
lines, valve and booster and or mc... all items available in my for sale add from the weekend....
GSR-TRBO-DA
Sep 16, 2007 06:32 PM
Vcastro
Oct 13, 2006 08:46 AM
jonyb
Nov 27, 2003 04:13 PM
phantom_sol
Oct 5, 2003 10:22 AM
