2000 Accord Rough Idle
Old Mar 16, 2018 | 04:35 PM
shanec80's Avatar
Default 2000 Accord Rough Idle
Hi Folks,
I've been chasing this problem for quite awhile now- hoping someone can shine some light on the subject.
Specs: 2000 Honda Accord 4Cyl VTEC, 150K miles
Problem: intermittent rough idle, stumbles until I get on the throttle, then accelerates and runs clean. The exhaust note at idle almost seems like it has a misfire. When I pull the plugs, they are tan and clean, which makes me think it's not a bad cylinder.
Also, it doesn't do it consistently. It will run smooth in the morning, but in the afternoon it has a rough idle, for example.
What I've done/replaced so far:
-Fuel system cleaner
-Cleaned throttle body
-New Air Filter
-New plugs & wires
-New IACV
-Cleaned EGR Valve
-Valve adjustment
-New PCV Valve
-New Ignition rotor/cap
After replacing something, it seems to helps little bit, but the problem still persists. The most recent thing I did was the rotor/cap. Before I replaced these, the engine would almost want to die at idle. Now it's much better, but still hesitates/stumbles at idle.
It's giving me codes P0420 (bad cat) and P1457 (EVAP canister/solenoid).
Internet research and a mechanic have both told me that the bad cat is likely a result of the poor idle, not the cause. I've also been told the EVAP does not effect how the engine runs. I'm waiting to fix these issues until I pinpoint the rough idle.
Any thoughts?
Thanks!
Old Mar 16, 2018 | 05:52 PM
holmesnmanny's Avatar
Default Re: 2000 Accord Rough Idle
check mechanical timing, could be off a tooth
if good, compression test to be sure the engine is in good shape
Old Mar 18, 2018 | 11:55 AM
Mason Edmison's Avatar
I would check for a vacuum leak around the intake area using carb cleaner or water. Possibly check the MAF sensor and give the contacts a good clean with electronic parts cleaner.
What kind of plugs and wires did you use? Hondas are very picky about their spark plugs. They even go so far to list specific part numbers for the plugs (Denso or NGK).
I, too, recently had the p0420 code. I would replace the the cat O2 sensor at the cat and see if that takes care of the P0420 code. if not, I put a magna flow direct fit on mine and it works great no more code ( I think it was like 150 ish on Amazon).
Old Mar 19, 2018 | 03:44 AM
none of the cars in this subforum have a mass air flow sensor
Old Mar 19, 2018 | 04:07 AM
right, I stand corrected. Sorry sorry.
Trunkzdbz
May 17, 2014 12:21 AM
DavidLee97
Sep 11, 2011 06:09 AM
Hunng
Oct 11, 2008 02:43 PM
Honda_Accord_Type_R
Dec 9, 2005 08:17 AM
Accord88
Feb 23, 2003 05:53 AM
