94 Accord lx starts then immediately dies after
Old Mar 15, 2018 | 07:38 AM
dslatet455's Avatar
Default 94 Accord lx starts then immediately dies after
I have replaced ignition, main relay fuel pump filter and injectors but still does the same thing. It start then dies. If I spray starter fluid into the intake it will run until I stop spaying. Help this has been a nightmare honda and I actually like hondas plz help
Old Mar 15, 2018 | 01:36 PM
smithers646's Avatar
Default Re: 94 Accord lx starts then immediately dies after
Sounds like fuel prob, but could be other things. Do you have fuel pressure on the rail? you swapped a bunch of pieces- does the fuel pump actually turn on, and pump? You swapped injectors- does fuel make it into the cylinders?
You need fuel, spark, and air(/compression), and timing to make it run. You need to do some testing to find the problem.
(we all like Hondas, too- but this ain't Honda NA. This is a chatboard- which is way better!)
Old Mar 15, 2018 | 01:50 PM
dslatet455's Avatar
Yes I tested all of that Ive ran direct power to pump even. Why would I not test. Ive even trsted the injectors one was clogged.
Old Mar 15, 2018 | 10:18 PM
holmesnmanny's Avatar
check that each injector has power at the black yellow pin when you turn the ignition to on, if it has power then I would pop open the ecu and check for burned spots, burned spots means the ecu is likely bad, but even if the ecu looks good I would swap it out with another from the junkyard
rustyhog
Sep 7, 2016 07:05 PM
Jackemup92
Sep 2, 2013 10:18 AM
KandiQid
Jul 11, 2012 04:27 PM
WaYtOoLoW
Feb 24, 2010 06:30 PM
