1994 Honda Accord D4 Blinking and check engine on
So this happens usually only in the mornings I have yet to see it happen any other time but when I go down for work and start my car sometimes it stalls sometimes It doesn't start right away but when it does start my check engine light turns on and my D4 starts blinking but after driving it for a little bit i will turn it off and turn it back on it goes away and doesn't do it for the rest of the day please help?
Pull codes from blue connector by glove box. D4, cel srs and abs will blink respective codes if any when key is turned to ig2 but not run
If you have any soldering skills you can repair this issue fairly cheaply.
Please post an update. Thanks.
osbunjosh
12
Mar 3, 2013 12:20 PM
Leighza
May 29, 2007 08:20 AM
BOOSTEDgreeneg
Sep 6, 2005 10:06 AM
