H22 trans swap on h23a bluetop accord
Alright so I have a h23a bluetop in my cg accord coupe. The long gears are killing me car feels slow as ***** ... Can I swap in the h22 trans from a prelude without changing CV axeles and motor mounts and a bunch of other things? If it's a straight forward tranny switch I have no problem swapping it but I need the car for work and definately don't want to be out of commission for more then a day or two. Basically my question is what is needed for the swap.
Should be an identical casing so it should be very smooth. If you post the transmission code we could be 100% sure. You could always just swap the diff and final drive and that would help.
BrysonIsAScammer
Sep 19, 2004 10:14 AM
