Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Low Beams don't work - High beams do - 02 Civic LX
Old Mar 11, 2018 | 04:34 PM
Kirk Hoey's Avatar
Default Low Beams don't work - High beams do - 02 Civic LX
So the low beams don't work but I can use the high beams. Checked fuses, replaced bulbs and still no go....so did a little research and then replaced the multi-switch. Still no go...Any ideas on what else this could be? Thanks a bunch
Old Mar 11, 2018 | 05:54 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Low Beams don't work - High beams do - 02 Civic LX
Cause may be due to the multiplex control unit (mcu) not sending ground (-) to the headlights. The mcu is built into the under-dash fuse box.
First test for power (+) at the headlight bulb connectors. With the headlight switch turned on, check for power (+) at the Red/Yel wire terminal on the left headlight bulb connector. Also check for power (+) at the Red wire terminal on the right headlight bulb connector. -- If there is power at those wires, the issue is that there is no ground (-) source being sent to the connectors; which may be due to a faulty mcu or wiring issue.
Old Sep 28, 2019 | 04:13 AM
Brian Cervantes's Avatar
Check id your car falls under recall. There is a recall for the low beams due ro a faulty wiring harness that over heats
Old Sep 28, 2019 | 11:25 AM
Gerardo Rod's Avatar
Hi everyone, I am new here and I hope I can help a little, I had the same problem as you in my civic 01, change fuse check lights and everything was ok, the problem, I am almost sure it is the directional lever connector, disassemble the cover of the steering wheel and disconnects the lever I am almost sure that part is burned. Sorry for my bad english hope my replay can help you.
mgabe
Nov 11, 2016 04:48 PM
pr1madona
Honda CR-V & Element
Oct 1, 2016 11:52 AM
russlan44
May 18, 2009 09:19 PM
powerwagon340
Dec 24, 2008 01:07 PM
Jacen
Mar 22, 2006 10:51 PM
