To rim screw beadlocked wheels or not, that is the question.....
What the general consensus on using rim screws on the inner part of the wheel, while using beadlock on the outer? Btw, the wheels are 13x10 running 24.5x9 MT.
I’m running the same setup. Bead locked outside, screwed inside. I wouldn’t run them without the screws and I don’t know anyone else who does.
Thanks. I bought these wheels used and they were not drilled. However I had seen others with the same size wheel using inner rim screws.
