2001 civic oil pump install help.
I've seen multiple videos on timing belt, water pump and
replacement. But none of them show oil pump removal and install. Does anyone have a video or link to one that shows the procedure for how this is to be done? I know I could buy a Chilton or Haynes repair manual but I'm also a visual learner, and it would be most beneficial. Thanks
I'm not replacing it, but I am replacing the o-ring behind the pump that is the possible culprit to my oil leak, which is the source 90% of the time coming from behind the timing chain cover. As I do this I'm also replacing everything behind the timing chain covers with a kit. I believe I need to take my exhaust down which runs under the back of the pan. Also the dust shield and transmission bracket (not sure about that). But I just feel better to see someone doing it. Like I said I'm a visual learner as well. Thanks.
