Stupidly optimistic overtaking results in big crash
Sometimes all it takes is one poorly planned pass to ruin everyone's day. Have a look at this bit of in-car video from the Hoosier Super Tour at NOLA earlier today.
(Skip to 7:17 if it doesn't do so automatically)
You're riding along with Greg Amy in the #33 STU Honda Civic Si as #105, a T4 Mazda MX-5, attempts a wildly optimistic overtaking maneuver and punts Greg off the road at high speed. Well, you can see what happens next.
To top it all off, the driver of 105 threw profanities and inappropriate gestures at the stewards when they penalized him for his move.
Last edited by boxedfox; Mar 4, 2018 at 07:24 PM. Reason: Timestamp didn't come out for some reason
dude seems to have bad luck...his integra got smashed @ watkins glen
is the car totaled?
edit:
tried posting the proper link but honda-tech wont let it embed properly
if you click the title where it says "STU Crash" it will work if you open it in another window
is the car totaled?
edit:
It sounds like the roll was slow enough that it didn't cause that much damage. New windshield, body panel repair, straightening of the A pillars, and new sheet metal for the roof.
Here's an edited 360 degree video from the car that was sitting behind when the incident happened. The MX5 does appear to turn into the Honda at the apex, which is pretty nuts.
I wouldn't want to drive anywhere near that miata. If you watch the minute leading up to this he dive bombs into multiple corners just to lose a lot on the next straight, almost clips the black vette at turn 1, then the Integra at turn 2.
Am I the only one who kind of thinks that was an almost okay pass? he had the speed. if only he'd given the civic room to track out (assuming he didn't hit him). It does look like he sort of corrected/turned into the civic which was effd up.
I was thinking the same thing, like he was trying to blocking or something, but than again I suck at w2w racing.
Hmm. You know, I'm thinking about this, and I think that if the Civic went to block the MX5 into that corner, this crash probably wouldn't have happened. The Honda is significantly faster in a straight line. He could have just turned in early, hung the MX5 out to dry on the outside, and just motored away through the straight.
There's a reason he didn't block though. Thee two cars aren't in the same class. The Civic is in Super Touring Under and the MX5 is in Touring 4.
Results from the NOLA Hoosier Super Tour Race
If I was driving the Civic, I wouldn't expect a car in a completely different class to attempt a low percentage pass in a high speed corner.
Last edited by boxedfox; Mar 6, 2018 at 04:41 PM. Reason: Original wording was funny. Made it sound like I was researching something I already looked up.
Miata driver was begging for a wreck, and made one happen.
The contact was unfortunate but I don't think the move was that crazy. If you are behind the wheel of a Miata and want to win anything, you have to divebomb everyone. At the very beginning of the video, I was thinking to myself, "The STU back markers sure are holding up the lead T4 cars. Someones gonna get frustrated and do something ballsy"
Watch the video at 6:30 and you will see the xx-5 on the right. Watch the inside pass he then does, using a ton of curbing and chucking his car right in front of the flatout motorsports miata (I think it’s an STL car and a national runner). He does a fantastic job here of threading the needle in a slower part of the track. I don’t think the burgundy car is a guy who ran out of talent. He prob just expected room on the inside. It’s what Miatas do. They will always slide in way deeper on the inside vs a FWD car. They are far better balanced.
wonder if it was that or running his mouth to the officials. My experience is there are 2 gaurentees to get hammered:
1. Passingracing under yellow
2. Picking a hostile fight with the officials.
The incident sucks but but I don’t see it as more than a racing incident. I don’t know if he has any history either so just judging this video.
This is the kind of stuff that concerns me. Watch the greenish car in the mirror. He jumps the start before the green flag....then wrecks a guy and the car is totaled.
https://youtu.be/9P7LylbMCFA
What happened to that guy?
Yes, and the number of cars in the class too. Unless there's a very large number of cars in the class, they'll generally get mixed in with other classes. In some instances they'll do things like a split start, where they'll physically split off a few classes into a separate group within the same session, and give them the green flag after the first group. This gives the faster classes breathing room at the opening stage of a race.
i don’t know. That was SCCA at Sebring and it’s usually 50-70 Miatas running. I have been running just NASA for now because the 2 bodies require diff tires.
NASA has been Running 4 classes together with split starts as somebody here mentioned. You have about 10minutes until the GTS4 type cars lap you.
agree. And anybody who is around any wheel-to-wheel with Spec Miata fields.....you know very well it’s called SpecPinata for a reason. It’s not that they drive like fools. The front runners are insanely good. Those cars come in with donuts on the doors and damage because you can’t drive any softer and win. He is not driving a cheap chumpcar himself and not looking for damage on his NC Mx-5 for sure. If you have 1/2 car width inside....a Miata or GT roadster will stuff it every time.
3 words.
**** THAT GUY
Definitely optimistic but not that insane in my opinion. I think it is reasonable to assume the Miata driver thought there may have been enough room to get the car in there. But the Miata driver was also driving aggressively leading up to the incident.
If you watch the white Civic infront of Greg and compare the lines they both take into the corner, Greg seems to take a defensive line on entry. Especially when you watch the line Greg takes in the laps leading up to this one. Greg takes a much wider entry into the corner on previous laps. But on the lap Greg gets hit, he seems to be defending and in my opinion turns into the Miata when looking at his on board. However, looking at the onboard from the blue and orange Miata from behind, it looks like the Miata turns into Greg.
My decisions if I was a race steward would be no penalty and it would go down as a racing incident. The profanities and poor treatment of an official would be the reason Mr. Miata would be getting punished, not his driving.
It's easy to play Monday morning racecar driver in these types of things.Racing is dangerous and not without incident and we all assume the risk when we strap in.
CivicSiRacer
10
Jan 10, 2011 03:14 AM
FLATOUTRACING
17
Jun 9, 2004 08:16 PM
