91 Crx Dx Crank no start HELP!
Back story of what I've know been fixed and or touched
new and replaces ( in order as replaced. Only in the last couple months)
fuel pump
fuel filter
Cap and rotor
Main relay
clutch.
start was removed and cleaned up.
I did the clutch last week after all said and done went to work delieving in crx got home and had to go out battery dead. So replaces alternator. Got it put back together. Wouldn't crank so removed starter cleaned it up. Got crank now no start. Pump priming no check engine light. Got fire. Checked all grounds cleaned them up. Relay clicking and seems to work.
go it started once for about 5 seconds with starter fluid.
check all fuses
Has fuel smell in throttle body so fuels getting in there.
Help im beating my head against the wall and in not a great financial state. Can't throw parts at it.
if anyone can help with a phone call or anything Dm me. Otherwise those ideas around.
thanks Quayle
fuel pump
fuel filter
Cap and rotor
Main relay
clutch.
check all fuses
thanks Quayle
Sounds like all you've done so far is throw parts at it....
Pull out the injectors and ensure all are spraying. Pull out spark plugs and ensure all are sparking. Check mechanical and ignition timing. Check compression.
vplukas101
17
Dec 24, 2012 03:23 PM
crxvtec_jdm17
14
Nov 9, 2012 04:38 PM
Arthas
Sep 2, 2010 06:42 AM
