a/c 99 acura cl 2.3
Old Mar 3, 2018 | 09:00 PM
aasgaard's Avatar
Default a/c 99 acura cl 2.3
acura cl 2.3 1999. ac works great at night. but during the day when over 75 degrees outside it hardly works. i do have a slow leak
Old Mar 3, 2018 | 10:31 PM
holmesnmanny's Avatar
Default Re: a/c 99 acura cl 2.3
could just be low on refrigerant, condenser is excessively dirty, compressor is going out
find and fix the leak, the valve cores tend to be the number 1 leak location, adding some refrigerant with uv dye and using a leak detector kit of glasses and uv light and run the ac for a bit at night, then check in the dark
fattyomattyo
May 11, 2014 07:45 AM
KrAzYdc2
Aug 6, 2008 03:57 PM
