Honda accord 2.3l VTEC
Old Mar 3, 2018 | 03:54 AM
Oussou's Avatar
Default Honda accord 2.3l VTEC
Good Morrning, I have a Honda Accord 2002 2.3l VTEC with initial tire 195/65 R15 and I want to put new tire 225/45 R17 then my question is: Is there any technical problems with this modification & how wil be the vehicule performance after this ( fuel consumption & other).
Thank you.
Old Mar 3, 2018 | 04:12 AM
angrysmileyface's Avatar
Default Re: Honda accord 2.3l VTEC
It's a wider tire so your rims are going to be bigger and require more force to keep moving probably increasing your fuel consumption. Also I'd have reservations about the front tires rubbing while sharp turning. Would suggest getting a tire shop to test fit one or both of your front wheels
Old Mar 3, 2018 | 05:41 AM
Fitz Williams's Avatar
10 Year Member
I have a 94 Accord and I changed to 17"rims and I use 215/45 on the front, and 225/45 on the rear. The 215 is closer to the original diameter, and not quite as wide. The 225 would rub the fender on the outside of the tire. But mine is also lowered about 1 1/2 inches. The offset of the rims also makes a difference. I use +45 on the front and +40 on the rear. It's what works for me. Others may vary.
Old Mar 12, 2018 | 12:03 PM
Oussou's Avatar
Thanks a lot for your advice.
Old Jan 19, 2020 | 10:10 PM
Bigz3009's Avatar
I also have that question. Stock rims are pretty light. With little performance upgrades I brought 150k engine back to its original 145hp. is that enough for 16inch without loosi g speed or power I think 2.3l 17in is too big. Bought new right axel broke in half after upgrades while launching it. I have headers and down pipe to install which might compensate for buying heavier rim..there about 6lbs lighter than stock...
Stock rims
vandium
May 3, 2010 03:46 PM
Ash81
Aug 2, 2007 06:40 PM
ylen13
Jul 14, 2007 07:18 PM
ny153
Jun 8, 2007 06:56 PM
Rerun
Apr 13, 2007 12:47 PM
