96 accord stumper
Old Feb 27, 2018 | 01:06 PM
tim73's Avatar
Default 96 accord stumper
Hi guys, I got a 96 accord Lx f22b2(non-vtech). So, it turns over fine and is trying to fire, just won't. Checked compression, 190 all four cylinders, checked coil, nice bright spark, checked each plug wire, nice white spark. Checked fuel pressure at the banjo bolt, 60 lbs cranking(it won't start). I replaced plugs with Ngk5's as the old ones were really black and sooty.
It ran for like 30 seconds after new plugs, but it would only idle...would try to die when I gave any throttle. So, now, new plugs are black and sooty. It's almost like too much fuel? Pulled vacuum line off of regulator, no gas cane out. Ideas?
Old Feb 27, 2018 | 04:36 PM
hondaslave1342's Avatar
Default Re: 96 accord stumper
No engine light illuminated?
Old Feb 27, 2018 | 07:40 PM
tim73's Avatar
No, but it hasn't really ran. I did hook up my obd2 scanner and put on live data. Shows the ect is in the ballpark. Gonna try the coil tomorrow. See if swapping a new one makes any difference. It's sparking, just maybe not enough.
Old Feb 28, 2018 | 01:14 AM
holmesnmanny's Avatar
something is seriously wrong if you're getting 60 psi of fuel, is your fpr stock ? should be around 40ish
Old Feb 28, 2018 | 11:27 AM
tim73's Avatar
Fpr is out of the picture. I removed hose from side of rail(where it attaches to banjo bolt fitting). Hooked up my test gauge via banjo bolt fitting.
Old Feb 28, 2018 | 01:24 PM
tim73's Avatar
Changed out fuel filter, just cause it looked old. Removed the injector rail...to check if while cranking, injectors were shooting fuel. They were, I was worried maybe they were stuck open. But no. Tried new distributor and coil, separate and then together. Still no. Removed the valve cover to check timing marks...they appear dead on. I'm just about to give up on this thing, only thing I haven't really tried, is new fuel pump(still wondering how/why I got 60psi). Ideas?
OCwrencher
23
Jun 15, 2021 06:10 PM
onlymeplus3
Sep 30, 2017 07:09 PM
Codyaz
Feb 4, 2017 04:26 PM
MilitantPotato
Jan 17, 2017 02:17 PM
Bayourat
Mar 17, 2008 04:28 PM
