Please Help! 99 honda accord lx 2.3L f23a1
Old Feb 27, 2018 | 12:46 PM
ChrisBori's Avatar
Default Please Help! 99 honda accord lx 2.3L f23a1
I have 2 problems. There is wire that is not connected and I have no idea where it goes, it seems to be on the same line as the map sensor wire This is the vacuum line.
. Also, there is a vacuum line that is not connected and i don't know where to connect it to. Please help.
Old Feb 27, 2018 | 09:47 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Please Help! 99 honda accord lx 2.3L f23a1
I believe on the 98-02 cars that is the main vacuum feed for vacuum solenoid that controls the rear mount on AT cars. If you do not have an AT or the vacuum controlled mount, then that should be capped off.
Electrical connector looks like it may be for the ECT located under the distributor. If you could note what the two wires insulation colors are that would confirm what the connector is for.
Old Mar 2, 2018 | 03:04 PM
ChrisBori's Avatar
Thank you for responding. The plug only has one wire going to it and it is a greenish blue color.
Old Mar 3, 2018 | 07:34 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Take some clear photos of the wiring showing the color(s) at the black connector. It looks like it may be the connector for the transmission 2nd clutch pressure switch.
Old Mar 14, 2018 | 12:50 PM
ChrisBori's Avatar
It's the greenish color connector, I have no idea where it goes.
Old Mar 15, 2018 | 10:42 PM
holmesnmanny's Avatar
you need to peel back the wire loom and take a picture of the wiring as tech8 already asked so he can look up what the wire colors go with
Old Mar 18, 2018 | 12:33 PM
ChrisBori's Avatar
This is the wire.
fxfeguy
Mar 10, 2019 02:35 PM
Wxlry
Aug 9, 2018 01:01 AM
eddieo
Dec 26, 2017 12:09 PM
976
Jul 29, 2003 06:40 AM
