99 Accord v6 Engine swap compatibility
Old Feb 23, 2018 | 09:21 AM
Rarev6's Avatar
Default 99 Accord v6 Engine swap compatibility
Hello Honda brothers and sisters haha, i would like to know which engines would be a fit for my Accord v6 automatic. Which engine would help it’s performance, and all the names of the engines that could fit my Accord. Thank you so much, much appreciated. God bless.
Old Feb 23, 2018 | 05:14 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 99 Accord v6 Engine swap compatibility
J series engines have very similar blocks, its the change in the cylinder heads/intake/exhaust that increased the power.
98-02 J30 200HP
03-05 J30 240HP
06-07 J30 244HP
The other difference is the 98-02 had a 4spd AT while the later cars have a 5spd AT or 6spd manual.
Swap in a later J30(if you want to stay 3.0) with the appropriate transmission and wiring harness, but that would require modifications to make work with your older Accord.
Comptech did offer a supercharger for the 98-02 along with their headers net ~225HP to the wheels, so if Comptech still has this kit that may be the easier route rather than trying to swap in a later model engine/trans.
Old Feb 24, 2018 | 11:09 AM
Rarev6's Avatar
98-02 J30 200HP
03-05 J30 240HP
06-07 J30 244HP
Thank you so much!! I appreciate it, so in order to swap for a J30 (06-07) I would have to switch transmission as well?
Old Feb 25, 2018 | 05:24 AM
94 accord typeR's Avatar
Acura J32
Old Apr 11, 2018 | 05:38 AM
Ttrip's Avatar
98-02 J30 200HP
03-05 J30 240HP
06-07 J30 244HP
Hello, my name is T. I'd like to jump in on here to see if you could help out also. I'm going to be swapping my 99 honda accord V6 vtec to replace with another of the same. Does it have to be dropped from the bottom with trans or can just the engine be pulled from the top? Help needed asap with any and all info and/or videos
Old Nov 17, 2018 | 04:00 PM
Kingjames's Avatar
I have a 2005 Honda accord hybrid with 3.0l i-vtec, I swapped the engine for a 2007 Acura RL SHawd 3.5l vtec. I bolted all the hybrid components on to the 3.5l with no problems. And, it runs great for the first ten miles. Then I get a check engine light and it shuts down at 3500 rpms. I gives the PO 2648 which has something to do i-vtec solenoid wiring. The 3.5l is vtec, no i-vtec solenoid. Does anyone know what l have to do to the engine bay wiring harness to fool the computer, or in other words which wires do I change or cross to make it work?
violetteague
Jan 25, 2015 08:51 PM
v4lu3s
Mar 28, 2012 06:20 PM
accordcvcc78
Classic Hondas
May 16, 2010 10:25 PM
CNSK
Feb 3, 2010 04:18 PM
asbestos2001
Jan 6, 2009 01:32 PM
