Stripped rear Camber hole... what to do?
So I ran into a chassis problem.
I accidentally stripped the rear passenger camber bolt hole on my RSX.
How do I fix this besides redrilling or using those heli-coil kits?
Thanks
Thanks
Just to be clear, is this the hole that goes into the body or the one that is welded on the trailing arm?
Either cases best solution would be to cut, remove the bolt, then reweld in a new one...
jdurston
Suspension & Brakes
Feb 19, 2006 08:07 AM
