1997 honda hard to start makes a clicking noise takes a long time to start
Old Feb 11, 2018 | 03:12 PM
rickphipps88's Avatar
Default 1997 honda hard to start makes a clicking noise takes a long time to start
1997 Honda accord makes clicking noise but takes a long time to start if it starts
Old Feb 12, 2018 | 09:36 AM
brakedrum's Avatar
Default Re: 1997 honda hard to start makes a clicking noise takes a long time to start
  • Battery dying
  • Loose cable at battery terminal, or heavy corrosion at terminal
  • Ignition switch issues. Unlikely if no other power problems present
  • Most likely the Starter is failing (sometimes you can hit the starter with a hammer or tire iron, and if it starts fine afterwards, bad starter solenoid is the trouble)
If you know the battery is strong, and the Honda has the original starter in it, almost certainly replacement starter is needed.
Replacement is fairly easy DIY job, but the original starter may have one of more stubborn bolts holding it on. If you have one, or can get one, a breaker bar
might come in handy.
Old Feb 12, 2018 | 07:23 PM
holmesnmanny's Avatar
fortunately the starter is really easy to get to, it's pretty easy to swap out the starter contacts if you got a manual starter, i've had good luck with Pure Energy starters at rockauto
to test, check for voltage at the signal wire going to the starter when you turn the ignition to start and the car in neutral, if you got voltage it's likely the starter is bad
if you got a DEA or Viper aftermarket alarm it's possible the ignition kill function is malfunctioning
saintlewis
Feb 12, 2016 07:48 PM
magpie.1234
Jul 24, 2015 02:19 PM
1337knub
Feb 10, 2014 06:57 AM
lilsol89
Jan 5, 2009 03:57 PM
DAYUIZ
Jan 20, 2004 03:03 PM
