Seal replacement issue
Old Feb 10, 2018 | 01:07 PM
hondaslave1342's Avatar
Default Seal replacement issue
I have a 1997 accord special edition f22b2..im in the process of changing the timing belt but decided to change the following seals also because of them weeping..
i really need the oem part numbers for the cam, crank, front balance shaft and since i have the transmission out both axle and front main seals..
Ive looked at online honda dealer schematics but hard to figure out..its a non vtec..any help is geatly appreciated..thanks
Old Feb 10, 2018 | 06:50 PM
Default Re: Seal replacement issue
2.2l f22b2 automatic..thanks
Old Feb 10, 2018 | 08:10 PM
holmesnmanny's Avatar
they gonna be under Crankshaft, Cylinder Block, and Camshaft sections
Old Feb 12, 2018 | 02:14 AM
thanks..the only one im having trouble with is the transmission seals for both axles..any help is much appreciated
Old Feb 12, 2018 | 12:34 PM
PerformanceFirst's Avatar
https://www.hondapartsunlimited.com/...n-housing-scat
I'm guessing 28 in this figure.
Old Feb 12, 2018 | 07:20 PM
it might depend on if you have an auto or a manual, the other seal will be in the torque converter housing
Steph82
Apr 7, 2014 06:35 AM
partialresponse
May 25, 2010 06:02 PM
91zSi
Jan 4, 2006 01:19 PM
92LudeSR
Sep 8, 2005 09:13 AM
david90
Oct 14, 2003 12:14 PM
