02 accord
Old Feb 10, 2018 | 06:56 AM
Sam.R's Avatar
Default 02 accord
turn on ignition, fuel and engine temp gage's don't work. starter turns but wont start. Wait 3 to 4 seconds, gage's come to life car starts. It used to start immediatly!. what could the problem be ?
Old Feb 10, 2018 | 08:19 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 02 accord
Next time it does that, jiggle the key and see if that affects how long the gauges are affected.
If there are many keys or heavy charms on your key ring this may cause excessive wear and misalignment of the contacts.
If using only the key allows the car to start normally then the ignition switch is probably worn out and will need to be replaced.
~$30 from Rockauto.
Old Feb 11, 2018 | 09:51 AM
Sam.R's Avatar
All dash light's and warning light's come on immediately as does the heater blower fan. Failed to mention that a aftermarket remote starter was installed prior to my purchase. ill keep wiggling the key. thank's for the reply!
Blaze45
Nov 29, 2017 12:07 PM
bluelights81
Dec 29, 2013 01:51 AM
Shaunybo1
Nov 23, 2013 08:05 AM
Rebel Star
Jan 27, 2009 12:08 PM
