Negative terminal replacement car no start
Old Feb 9, 2018 | 06:45 PM
604's Avatar
604
Default Negative terminal replacement car no start
Hey everyone!
My 90 civic has the battery located in the trunk and I just replaced the negative terminal and now the car no starts. The lights will turn on for a second but then dim out and die. Tried jumping the car too because the battery isn’t the best and it wouldn’t start just clicks but the interior lights turn on. Could this be the main relay? How could the main relay pop even though the battery terminal was disconnected? Really stumped on this. Haven’t tested the relay yet but that’s next. Let me know. Thanks!
Old Feb 9, 2018 | 11:13 PM
SKO's Avatar
SKO
Default Re: Negative terminal replacement car no start
Sounds like a bad contact. Make sure you don't have it grounded to a painted surface.
Old Feb 10, 2018 | 04:40 AM
Grifty's Avatar
Sounds like a bad ground, check the wire is secured to the terminal properly and make sure the chassis gound is on bare metal
E Es Won
Honda Civic (2001 - 2005)
Dec 13, 2013 05:06 PM
bdubnyc
Sep 4, 2008 07:07 PM
robble36
Oct 16, 2007 07:20 PM
HondaHemi
Dec 6, 2005 10:10 PM
dumbchild
Sep 3, 2002 03:25 PM
