Manifold Fabrication Materials: Turbo Flange, Exhaust Flange, Weld El's, etc.
Old Feb 7, 2018 | 09:23 AM
Alex Trebek's Avatar
Default Manifold Fabrication Materials: Turbo Flange, Exhaust Flange, Weld El's, etc.
Brand: Mazworx
Price: $200 Shipped, OBO
I started making my own equal length divided manifold, but I'm running out of time to finish so I just bought one. I had everything complete except the WG flanges and had separated it to to do the finish welding and milling for the WG tubing. What you see is enough to complete a manifold, plus extra unused weld elbows. Included is everything you see, I'll outline what exactly that is.
Turbo Flange: Divided T3
Exhaust Flange: D16
90's: Schedule 10 SS Weld Elbows
Some have been cut to angles other than 90's. This was all done in a jig to retain the proper circumference of the pipe so the transitions are smooth. The merge collector was all tacked together but I separated it because I was getting ready to cut the openings for the wastegates. You can see where I started milling one side of the collector. They have been heated and reshaped to fit the opening of the turbo flange for a smooth transition.
The merge collectors were welded with backpurging so there isn't any sugaring on the other side. Everything is usable.
The weld els to to the right of the merge collector have not been touched (QTY 7) and the straight piece is 2ft long. The others have been tacked, but are in fine shape. The flanges have a little material on them from early fab where I had to weld rod between the flanges to hold them in place while I ran the first runner. This does not affect the function, and can be ground off before finish welding.
Thanks for looking.
Old Feb 9, 2018 | 10:19 PM
kutlee's Avatar
Default Re: Manifold Fabrication Materials: Turbo Flange, Exhaust Flange, Weld El's, etc.
Please post pictures
Old Feb 11, 2018 | 03:47 PM
There is a picture of everything included in the original posting. Is there something in particular you want to see?
Old Feb 14, 2018 | 07:15 AM
Geis's Avatar
Yeah, I want you to see the top of the screen where it says "effective immediately" and specifically tells poster that they need to include pics of the items they're selling with a sign that has their username on it. Do so, or this thread will be locked.
Old Feb 19, 2018 | 12:13 PM
I included a picture when I initially made the post. Same as I have always done when I post on the classifieds. For whatever reason the image stopped loading. Re uploaded it. It's working again.
BoostFlow.com
Nov 2, 2011 10:00 PM
808DB1
Welding / Fabrication
Feb 22, 2008 05:04 PM
nitroice40
Apr 6, 2006 03:11 PM
b18c5GT2871R
Mar 19, 2006 05:11 PM
SOHCD16y8
Jun 10, 2005 08:04 PM
