1999 civic ex brake lights not getting brighter
Old Feb 7, 2018 | 07:06 AM
Ryan Abney's Avatar
Default 1999 civic ex brake lights not getting brighter
Hello my name is ryan and I recently purchased a 1999 Honda Civic ex 2 door coupe. I’m haveproblems with my brake lights not lighting up/getting brighter when I apply the brake. When I hit the brake nothing happens it doesn’t get brighter or anything. I’ve checked all the fuses, relays, etc. I replaced both bulbs. I also replace the brake light switch just to be sure and still nothing. I’ve heard there is a connector behind the left side panel in the back seat that is known to short out or cause problems. Does anyone recommend anything else before I start this year down?
Old Feb 7, 2018 | 07:15 AM
mk378's Avatar
Default Re: 1999 civic ex brake lights not getting brighter
The brake light fuse is under the hood. The horn is on the same circuit. Does the horn work?
Check that there is power to the brake light switch. One wire should be live all the time and the other one goes live when the pedal is pressed.
If the lights are on the moving part of the trunk lid, it is common for the wire to break where it flexes every time the trunk is opened.
Old Feb 7, 2018 | 07:54 AM
Ryan Abney's Avatar
My horn works and the fuse is good. My brake light are not on the movie part of the trunk lid. IF I’m correct I beleive the brake lights are the same as the taillights and they’re just supposed to get brighter. The bulbs are two prong bulbs one for low one for high. The problem is they never brighten up or light up like I’m braking. When I shut the car off they turn off but when I turn my lights on they are always on. I readjusted the brake switch multiple times to see if anything changes and nothing changed.
Old Feb 7, 2018 | 08:38 AM
NVturbo's Avatar
O.G. triple O.G.
replace the bulbs. IIRC, they are 1157, dual filament...which means one is for the "parking lights" and the other is for "braking". It looks similar to a 1156 but on the bottom screw shell, it has 2 tabs...and of course you can see the 2 wire filaments inside the glass.
YOU'RE WELCOME.
Old Feb 7, 2018 | 09:34 AM
Ryan Abney's Avatar
I’ve already replaced the bulbs and they are the dual filament. They are 7443 bulbs that Slyvania (bulb company) says fits my model
Old Feb 7, 2018 | 02:08 PM
mk378's Avatar
With brake pedal pressed, the larger bright filament should come on. With the light switch on, the smaller dim filament should be on. With both, both filaments should be on.
Do all three of these tests and report back. Also, does the center brake light work?
Xzay01
Lighting
Jun 14, 2013 08:53 AM
Peepers
Honda Civic (2001 - 2005)
May 23, 2012 05:16 PM
91b18a1ls
Mar 19, 2011 10:24 PM
waldo1212
Aug 19, 2010 04:44 PM
phrenzykEG6
Apr 12, 2010 08:54 AM
