CONCLUSIVE? Valve cover gasket stock part number
Old Feb 6, 2018 | 10:35 AM
windnsalsa's Avatar
Default CONCLUSIVE? Valve cover gasket stock part number
ACCORD EX 4 CLY 2000 2.3L 2254CC L4 :
I've tried forum and internet search and a challenge to find much and definatively if they are they are exactly the same part. Wanting to make a purchase for a valve cover gasket. I've ran across either or both part numbers below, sometimes one is a set, other times it's just a gasket alone with either part number 12341-P0A-000 or 12030-P0A-000. Prices vary quite a bit, depending on the part # for the set.
Any 100% conclusion? Thanks
Old Feb 6, 2018 | 11:20 AM
holmesnmanny's Avatar
Default Re: CONCLUSIVE? Valve cover gasket stock part number
https://www.hondapartscheap.com/auto...ead-cover-scat
so the first one
or one of these, i prefer felpro or beck arnley
https://www.rockauto.com/en/catalog/...r+gasket,10710
Old Feb 6, 2018 | 11:32 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Honda Part No.12030-P0A-000 is the set, which includes the following:
  • Headcover gasket (Honda part no. 12341-P0A-000)
  • Spark plug tube seals (Honda Part No.: 12342-P2F-A01)
  • Head cover washers (Honda Part No.: 90442-P0A-000)
If you only want the head cover gasket by itself, then order Honda part no. 12341-P0A-000.
Old Feb 6, 2018 | 03:26 PM
windnsalsa's Avatar
the net is confusing about this but what I am seeing is that the 12030-P0A-000 is generally the set whereas the 12341-P0A-000 is the gasket only. But, some internet vendors would indicate the latter as a set as it includes the gasket 12341-P0A-000 as well as part numbers for the spark plug tubes and washers.
I am relying on the following 2 vendors as more official. Thanks
estore.honda.com
hondapartscheap.com
Old Feb 6, 2018 | 07:33 PM
estore.honda.com
hondapartscheap.com
all you gotta do is look at the diagram i posted, and tech8 explained it in more detail
FinzWake
Nov 23, 2015 07:55 PM
ricechris121913
Engine Management and Tuning
Mar 7, 2014 04:25 PM
MRturbo
Mar 11, 2008 09:59 AM
kreamy
Mar 19, 2004 09:53 AM
vtec.dc2
Jan 27, 2004 07:32 PM
