Heat not working
Old Feb 4, 2018 | 04:41 PM
Fonziief90's Avatar
Icon4 Heat not working
So the heat in my 90 EF hatch doesn’t work I put it on 1,2,3,4 and it does nothing. Anybody know what’s wrong?
Old Feb 4, 2018 | 04:59 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Heat not working
By 'it does nothing', i'm assuming you mean the blower isn't working?
1 - check your fuses.
2 - check the blower motor - the brushes may have completely worn out. You can try applying 12V directly to the motor and seeing if it runs. If it doesn't run with 12V, replace the motor, if it does run, get a meter and a wiring diagram and start chasing it down.
3 - if the blower works on only a few of the speed settings (the higher ones) and doesn't work on others (the lower ones), you need to replace the blower motor resistor. I'm not sure if this being bad can cause the blower to not run on any setting...
Old Feb 5, 2018 | 04:27 PM
Tyson's Avatar
https://honda-tech.com/forums/honda-.../#post43614304
Old Feb 7, 2018 | 03:05 AM
hichamaziz's Avatar
check your fuses.
90ED6LSV
Dec 31, 2012 06:42 AM
94trouble
Nov 11, 2010 05:50 AM
88ef91r32
Nov 12, 2008 04:12 PM
ef8ryder90
Oct 23, 2006 06:06 PM
Sedat1ve
Dec 11, 2002 06:38 PM
