92 Honda Accord DX shift lock
Old Feb 3, 2018 | 03:00 PM
1963Shelby's Avatar
Default 92 Honda Accord DX shift lock
I have a 92 Honda Accord Dx was running one day and the next day it would not start have tried the fuel relay and the fuel pump checked fuses and looked for broken wires one thing we noticed was that the shifter was locked can this prevent the car from starting?
Old Feb 4, 2018 | 01:21 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 92 Honda Accord DX shift lock
It won't start, or it won't crank?
If no cranking then it is most likely the circuit for the shifter interlock and the neutral safety switch is causing an issue.
Use the key to push into the slot right of the shifter, place shifter into Neutral and see if the engine will crank, if not place it in other gears to see if the engine will crank.
If the engine will crank in any other gear other than P or N then the gear selector switch is either out or adjustment, filthy or busted.
Have you checked for codes by jumping the blue two wire connector located above the passenger side kick panel?
Jumper the connector with a wire, turn ignition to II(ON), watch the CEL or D4 lamp for flashing codes.
seklze
Oct 13, 2013 12:34 AM
leecivic
Jul 15, 2013 01:10 AM
RonMac562
May 12, 2013 06:26 AM
00siboy
Jul 28, 2011 10:01 AM
jdmdude
May 30, 2005 06:37 PM
