1994 accord wagon ex 5 speed speedo won't work
So first off before i messed with it, it would jump and vtech would work sometimes switched out vss and checked continuity and resistance on the 3 wires the yellow one had 970ohms of resistance so i tried fixing that but i couldnt find any wiring diagrams checked continuity from the back of fuse box to sensor and it was fine so some other wire there has high resistance but everything works besides speedo, tried giving the sensor a diffrent ignition power with a fuse still doesnt work and code 17 keeps coming on, doesn't move or do anything anymore could a bad cluster cause the code ??
Replace the sensor. Baring that you need a new circuit board for the speedo or the pins/wiring in the harness has degraded
the sensor was replaced and as for the wiring i bipasded the high resistance and still didnt work im hoing to test the cluster tommorow but i wanted to know if the cluster not working willit cause a check engine ??
No a failed Speed Sensor causes both CEL and a transmission light (if its an auto) The cluster is just a bunch of wiring to display incoming data to the driver. When I got my 94 EX, the speedo didnt work period until I replaced the speed sensor with an oem one. Ive had civics where the harness was faulty (Pins falling out) that required replacement. Regardless of whether you replaced the wiring, perhaps you should check the connector itself on both sides, they go bad too.
While not always promoting other forums (I know this user lives here too in the civic forums.)
Here is a wonderful tutorial for your experiance. Civic VSS troubleshoot/fix - D-series.org
gabeortega
Jun 5, 2017 06:59 AM
Matthew98DX
11
Oct 26, 2014 07:55 PM
