VTM-4 LIGHT ON!
sup HT , gotta 2003 pilot and my vtm light came on about a few weeks ago , no change in drivability , trans shifts smooth , i changed trans fluid (oem), rear end fluid (oem), disconnected battery to see if it would reset , light continues to stay on , any pointer on this fix
You may need to get a dealer involved to at least read the error code causing the VTM-4 light. A standard obd2 scanner most likely will not read the Honda system code involved. Finding out which code is display will give you a starting point to maybe a bad sensor. Then decide if you want the dealer to fix or tackle it your self.
natemoore
Jun 9, 2015 08:31 AM
xela9000
12
Sep 18, 2014 12:34 PM
Jaydeep
Honda Civic (2001 - 2005)
13
Jun 23, 2011 12:33 PM
grooner
Nov 21, 2010 07:06 AM
