Honda CR-V & Element 2WD & 4WD Element & CR-V
Jack/Lift Points if you have Running Boards (Gen 2 CRV)
Old Jan 31, 2018 | 07:24 AM
bmwstephen's Avatar
Default Jack/Lift Points if you have Running Boards (Gen 2 CRV)
All- Since I installed running boards in my car which block the original oem jack points, can anyone help me identify where the inner frame jack/lift points are? If you can take a picture that would be great
Old Jan 31, 2018 | 01:54 PM
Occidentalis's Avatar
Default Re: Jack/Lift Points if you have Running Boards (Gen 2 CRV)
I have the running boards - OEM. Didn't change the lift points, but the folded metal pinch weld points are terrible and bend kind of easily. Depends on the lift too. For some cradle lifts with two points on each side you'll need blocks like wood or hockey pucks to avoid bending the running boards. With a post lift or household jack just look under the middle, there's a big black metal spot where the frame comes together where you can put the jack. Don't put it under the tranny. Behind the oil pan, behind the tranny. Same kind of spot on the back.
Starting at 3:52 here you can see it just past the tranny
PatrickGSR94
Dec 16, 2008 06:05 AM
silentdeath12886
Jun 27, 2008 10:53 AM
Honda Crx
25
Sep 20, 2005 10:08 AM
funkylemons
Audio / Security / Video
May 31, 2002 08:03 PM
