ITR cat vs LS cat, size shape difference?
Old Nov 12, 2002 | 12:59 AM
b18bfreak's Avatar
Default ITR cat vs LS cat, size shape difference?
Does anyone know if there are any differences between the two? I know the LS cat is round and the GSR cat is flatter. How does the ITR cat compare?
Old Nov 12, 2002 | 08:42 AM
b18bfreak's Avatar
Default Re: ITR cat vs LS cat, size shape difference? (b18bfreak)
top
Old Nov 12, 2002 | 12:22 PM
zilverz's Avatar
The USDM ITR cat will fit in place of your LS cat ... but it has an 02 sensor hole you have to plug if your 92-95 LS ... and it does have a slightly higher Flow rate
[Modified by zilverz, 9:32 PM 11/12/2002]
Old Nov 12, 2002 | 12:29 PM
Ferrell's Avatar
Default Re: ITR cat vs LS cat, size shape difference? (zilverz)
The USDM ITR cat will fit in place of your LS cat ... but it has an 02 sensor hold you have to plug if your 92-95 LS ... and it does have a slightly higher Flow rate
BRAiN8
Feb 2, 2005 08:34 AM
b18bfreak
Jul 26, 2002 05:29 AM
newspeedR
Aug 1, 2001 02:31 PM
