Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
8th generation Civic AC compressor clutch
Old Jan 25, 2018 | 05:17 PM
Zebra's Avatar
Default 8th generation Civic AC compressor clutch
I bought a repair kit on EBay to rebuild the AC compressor clutch on a 2008 Civic LX - it has the belt pulley, the clutch and the coil. The new clutch is slightly different, as the raised interior spine is 4 mm shorter than the original. I wrote the seller, .but only got Chinese script. I have a feeling that they don't have a clue whether this height difference will affect performance. I don't know whether to put this new clutch on or not. Anyone ever encounter this issue?
Old Jan 25, 2018 | 09:14 PM
holmesnmanny's Avatar
Default Re: 8th generation Civic AC compressor clutch
it shouldn't be an issue, you just need to make sure the gap is within spec by measuring with a feeler gauge and using the appropriate shim or shims that came with it
austinsamson
Honda CR-V & Element
Apr 23, 2018 08:58 AM
spAdam
Jun 4, 2014 05:04 PM
