My prelude stalls when I come to a stop, whats wrong with it?
Old Jan 17, 2018 | 12:40 PM
SaltyMillennial's Avatar
Default My prelude stalls when I come to a stop, whats wrong with it?
I recently purchased a 1989 Prelude Si 4ws. About 2 weeks after purchasing the car it started stalling inttermittently. I have no idea what could be the cause, and input would be greatly appreciated!
Here's what happens:
It will start just fine, but after driving for a bit, (maybe 5-10 minutes, sometimes 30 minutes or more) it will stall when I come to a stop with the clutch in. When this happens I am not able to start the car with the starter, it only starts when I push start it. The motor cranks, but no start. I dont have a check engine light on, and I have no idea what the issue could be.
At one point I sent this text to my Dad:
"My car barley started and was idling at like 500-300 rpm and the check engine light came on. It died when I pulled into a parking lot, but it was still rolling, so I let the clutch out and it started again. Then when I got home I shut it off and tried to start it again, and it would crank with no start, but the check engine light went off."
It will also occationally not start when I park it. I pulled into a parking lot and shut the car off normally. When I tried to start it again in about 15 minutes, it cranked with no start, and I push started it.
Typically the car idles fine, and in the morning when I go to start it, it starts right up without any issues, and dies sometime after driving, usually in a busy intersection... Its super neat.
I have no clue what the issue could be, and any suggestions would be amazing. I havent replaced any parts yet to try to fix the issue, because I'm not sure where to start. Thanks!
Old Jan 18, 2018 | 11:39 AM
holmesnmanny's Avatar
Default Re: My prelude stalls when I come to a stop, whats wrong with it?
hook up a harbor freight fuel pressure gauge and see if fuel pressure is dropping off when it dies
check the outer mesh filter of the iacv for carbon buildup
Old Jan 20, 2018 | 05:57 AM
TimiK's Avatar
10 Year Member
Maintenance history?
Spark/distributor parts changed..ever? Valves adjusted, filters changed etc
Old Dec 20, 2023 | 10:51 PM
Donwon1988's Avatar
COOLANT TEMP SENSOR IS THE PROBLEM
osbunjosh
12
Mar 3, 2013 12:20 PM
batallic
May 15, 2008 04:00 PM
DelsoldS
Oct 2, 2005 05:40 PM
buzlink
20
Sep 12, 2003 02:28 PM
