Automatic Accord. After changing the oil, the transmission is bad
Old Jan 17, 2018 | 12:15 PM
Zopapp's Avatar
Default Automatic Accord. After changing the oil, the transmission is bad
I have an automatic Honda Accord LX (1997). F22B1 engine.
There was a motor defect. The engine was repaired. The car was standing for 1 year. At startup, the car every gear go forward. All grades was shiftable. After a few tests it was good. It was 100 km to go this way. The transmission worked very well.
I buy the transmission oil (Honda ATF DW-1). After the change, the error came again. Now I can not shift down as D4. The arm is in opposition (D4->D3) (can not be moved in D2 and D1).
What might be the problem? Contamination? Thinner oil and because is the seal hollow somewhere?
I did not read any such errors at other thread.
Thank you for your help!
Old Jan 17, 2018 | 12:23 PM
holmesnmanny's Avatar
Default Re: Automatic Accord. After changing the oil, the transmission is bad
likely too little fluid
Old Jan 17, 2018 | 12:35 PM
Zopapp's Avatar
I stopped a warm engine. The oil level is maximum.
Old Jan 17, 2018 | 01:34 PM
on some cars the car has to be off and for some cars the car has to be on when checking
did you measure the old fluid and put in the same amount you took out ?
Old Jan 18, 2018 | 11:09 AM
Zopapp's Avatar
For this type, the engine must be stopped.
Indeed. The old oil was larger. The old oil level was minimal. The new oil is much less, but its level is maximum.
Why can not I put all oil on?
Old Jan 18, 2018 | 11:35 AM
did you try clearing the codes ?
Old Jan 18, 2018 | 12:42 PM
Zopapp's Avatar
are not error codes
SCHonda2002
Nov 14, 2017 04:30 AM
sasanj
42
Apr 10, 2012 03:09 PM
Bad_dude
Apr 30, 2010 10:34 PM
oziking
May 29, 2007 08:22 AM
tomrx1
Jun 23, 2004 06:20 PM
