92 accord cranks but won't start?
Old Jan 16, 2018 | 12:32 PM
mete4d's Avatar
Default 92 accord cranks but won't start?
'92 accord 2.2L manual
was running fine 4 days ago. parked for the weekend and tried to start it 2 days ago and it will crank strong but won't start. replaced plugs, wires, it started for a few seconds very rough start and running rough before it died.
replaced battery same thing it was hard to start and ran for a few minutes ok before it got really rough and died.
Replaced the ICM and cranks hard but can't get it to start. I can hear the fuel pump and main relay click when I turn key to start position. Any ideas on what's next?
Old Jan 17, 2018 | 02:27 AM
Braap's Avatar
Default Re: 92 accord cranks but won't start?
Are you sure it's getting spark?
Old Jan 17, 2018 | 09:40 AM
holmesnmanny's Avatar
check mechanical timing
then check for actual fuel and check for blue spark using a tester
Old Jan 19, 2018 | 12:23 PM
mete4d's Avatar
It turned out to be the main ignition relay.
Had already checked spark and fuel though and both were good.
Though I did end up replacing the fuel filter, distributor cap and rotor for good measure.
Thanks for your replies.
Caleb Wilson
Nov 7, 2014 03:03 PM
Bienval23
Aug 18, 2014 12:14 PM
samvilay
Oct 31, 2009 02:46 PM
timhillu03
Dec 21, 2005 04:14 PM
rvanders37
Aug 3, 2005 10:51 AM
