Is a 4th gen preludes hub assembly the same size as a 5th gen?
Is a 4th gen Preludes hub/spindle assembly the same size as 5th gen Prelude? The reason i'm asking is because it would make going from 4 lug to 5 pretty easy.
Rear, yes. For the rear the 5 lug hub will go on the 4th gen spindle, but the spacing isn't quite right and the rotor will hit the caliper bracket, so grab the spindle too. Front I'm not sure, I used the front 5th gen knuckle/upright.
