Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
01 civic lx
Old Jan 6, 2018 | 07:48 PM
kmaesad's Avatar
Default 01 civic lx
Replaced the engine because son blew the original . Put on the original intake to newer engine. Having a severe surging problem { ideals 1500 then to 2200 and back to 1500 once warm.} At the same time code P0113 and P0715 showed up.Did replace intake gasket .
ANY HELP IS NEEDED ...
Old Jan 6, 2018 | 10:17 PM
toyomatt84's Avatar
Sanji
Default Re: 01 civic lx
Which throttle body did you use? You may have a clogged idle air control valve.
Old Jan 7, 2018 | 07:54 AM
kmaesad's Avatar
The one that came off of the blown engine.. I thought that I would use all known working parts from the old engine for the newer {used} engine , that I wouldn't have to worry about problems . Guess, I was wrong on that one .
Old Jan 7, 2018 | 07:03 PM
toyomatt84's Avatar
Sanji
Well, there still may be an issue with the throttle body needing some cleaning. It could probably work just fine, afterwards.
Old Jan 10, 2018 | 05:34 AM
kmaesad's Avatar
Well, went back to work on the car ( after being sick for almost 2 weeks ) . I removed the air cleaner and all the housing that went with it to check out the the throttle body and found that I didn't put the hose to the brake booster on to the in take . Connected it and started the car and ran the way it should . Problem solved.... I figured that I would recheck and make sure that all the connections were connected . Did that and found that a connection to the tranny wasn't fully connected - touched the wire and it pulled off very easily , got it to connect . Went to start the car and wouldn't start. the lights and eveything came on but no cranking , went to pull key out and it wouldn't come out of the ignition - couldn't even move the tranny into neutral . unhooked the battery and was able to remove the key from the ignition and move tranny thru all the gears . Hooked the battery back up and tried to start the car again and same problem of no crank and removal of the key until battery is disconnected . Whats going on here ???
Old Jan 10, 2018 | 08:14 PM
toyomatt84's Avatar
Sanji
Did you replace the ECU? If so, the immobilizer is probably locking the car down.
Colin
15
Oct 25, 2012 07:25 PM
cennouu
Mar 5, 2011 12:05 AM
red92
Mar 3, 2007 02:30 PM
undrcroft
Sep 22, 2004 07:40 AM
hondabuff
Oct 21, 2003 07:02 AM
