There is a slight gap between my upper ball joint and control arm. It is on the driver’s side. The passenger side does not have this gap. Not on the side of the boot but the top of the ball joint as pictured below.
Yep, definitely need to make sure the circlip is in there. Better get that taken care of before the balljoint falls out and you end up with a hell of a problem...
