Cranks but won't start
Old Jan 3, 2018 | 04:28 PM
Yama801's Avatar
Default Cranks but won't start
I was driving and my 1990 Civic just died. It acted like I was out of gas,but I had gas. Now just will crank but not fire up.i sprayed carb cleaner in the intake and it still wouldn't fire up. I'm guessing no spark,what should I do?
Old Jan 4, 2018 | 03:31 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Cranks but won't start
Any CEL's? Any blown fuses under dash and/or under hood? Is the main relay clicking and can you hear the fuel pump running when you turn the ignition to the ON position?
Old Jan 4, 2018 | 03:51 AM
rd91sib18c5r's Avatar
Take off the distributor cap and make sure the rotor is bolted on, screw comes out sometimes.
Also make sure you didn't snap your timing belt.
Old Jan 4, 2018 | 10:31 AM
Yama801's Avatar
How would I check the timing belt?
Old Jan 4, 2018 | 10:36 AM
Yama801's Avatar
Yes main relay is clicking when I turn the key. Also can hear fuel pump prime the injectors when you turn the key on. No check engine light on dash
Old Jan 4, 2018 | 03:37 PM
DaX's Avatar
DaX
Loved
Community Favorite
Peel back the carpet in the passenger floorboard and see if the ECU is flashing any codes.
Old Jan 4, 2018 | 03:38 PM
DaX's Avatar
DaX
Loved
Community Favorite
Pull off the valve cover and the upper timing cover.
Ruggeh
31
Jan 10, 2016 12:00 PM
Ef4doorwagon
16
Nov 19, 2015 03:37 PM
CHONCH2
14
Jan 21, 2010 10:26 AM
tlkolrod
Oct 3, 2007 03:39 PM
gutted-dx
20
Jun 18, 2005 12:03 PM
