97 Civic ex with 95 Jdm gsr swap. Cranks but will not start. Need help!
Old Dec 31, 2017 | 04:49 PM
KiNGDEE206's Avatar
Default 97 Civic ex with 95 Jdm gsr swap. Cranks but will not start. Need help!
here's story
97 Civic ex with Jdm gsr 95 swap
running and driving > blew hg > sat 7 months
finally redid hg. Resurface head. New ohm hg. Tdc correct
plug everything in > crank no start
my diagnostics: cel doesn't turn on when on ignition phase
fuel pump isn't priming
i replaced the main relay with a working order off car I see ran. Still no go
battery is good but I'll send it to autozone to get charged just to rule that out too
any ideas.
Checked fuel pump fuse under dash 15a. It's good
checked ecu fuse under hood. Top left corner I think 15a. It's good
tested ecu fuse under hood with a power light it turns onChecked fuel pump. No powerIm thinking main relay isn't getting power thus not powering main relayHow do I check if powers getting into main relay?
what other ideas ?
BTaylor
May 29, 2022 03:35 AM
SpeedRacerEX-R
11
Aug 2, 2016 06:10 PM
LiftNRace
Jun 1, 2013 01:22 PM
ANNiHiLATORS
May 27, 2011 07:43 PM
xwhitchx
12
Aug 1, 2009 08:13 PM
