Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Car loses heat while driving
Old Dec 30, 2017 | 07:31 PM
Karl schulze's Avatar
Default Car loses heat while driving
2001 Honda Civic lx
Great heat at idle
Does not overheat at anytime
Replaced temp sensor
Within two mile of driving car temp stats to drop and loses all heat
Let sit idle for 10 minutes and temp goes back up and car gives off heat
Old Dec 30, 2017 | 08:20 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Car loses heat while driving
Your thermostat is stuck open... if you watch your temperature needle, you should also see the temperature drop on gauge at the same time that you lose the warm air coming through the vents. When you stop the car and no longer have cold air being forced through the radiator, things will warm back up.
nicknack25
Feb 13, 2012 09:27 PM
GSR-T-
May 29, 2009 06:46 PM
invisible
Dec 1, 2006 12:35 PM
b_serious
Nov 7, 2005 11:28 PM
revvin9k
Dec 29, 2004 03:00 PM
