ECM upgrade
Old Dec 25, 2017 | 04:48 PM
Louie9332's Avatar
Default ECM upgrade
hello every one I have a 01 Honda accord ex COUPE 4cyl 2.3L ENGINE F23A1 AUTOMATIC TRANSMISSION I installed a 4" tip catback +catback muffler +header exhaust system and a cold air intake.so my question is can I upgrade my ecm for a high performance one and if so which one . thx
Old Dec 26, 2017 | 05:48 AM
GhostAccord's Avatar
Default Re: ECM upgrade
There are no simple plug and play high performance ECU's for this car. Only upgrades would be a full ECU and tune from a reputable shop.
The parts that you have bolted on do not require a high performance ECU. You should be good with the ECU that you have. Once you start looking at adding a larger throttle body, ported intake manifold and injectors. That's when you talk to a local tuner about what to use.
Old Dec 26, 2017 | 11:08 AM
Louie9332's Avatar
thx for the info will do that
sojara
Dec 15, 2011 01:27 PM
bemenaker
Jun 3, 2005 07:54 AM
granracing
Jul 16, 2004 09:10 AM
osbornsm
Aug 9, 2001 04:46 AM
