Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
03 civic stalls and won’t restart
Old Dec 25, 2017 | 11:55 AM
Puccillo's Avatar
Default 03 civic stalls and won’t restart
I have a 2003 Honda Civic ex that Has following mods:
- cold air intake
-headers, highflow exhaust
- performance chip
-stage 3 clutch
okay so here’s the issue.. car shifts and drives fine. But when coming to stop my engine sometimes stalls out and won’t restart. What would cause this?
Old Dec 25, 2017 | 06:20 PM
toyomatt84's Avatar
Sanji
Default Re: 03 civic stalls and won’t restart
Performance chip? Did you buy that off eBay or something? Because there aren't any "plug-in" style chips for this car.
Old Dec 26, 2017 | 02:32 AM
Puccillo's Avatar
Not sure, it came on it when I bought it. My battery is 4 years old, would this make it happen?
Old Dec 26, 2017 | 02:36 AM
Puccillo's Avatar
That’s the chip..
Old Dec 26, 2017 | 06:54 AM
toyomatt84's Avatar
Sanji
Yeah, I would remove that and see if your problems persist.
Old Jan 1, 2018 | 12:14 PM
Puccillo's Avatar
Icon4 2003 Civic EX idling problems (HELP!!!)
Alright guys, so I have my honda in at the dealer getting looked at but I need some of your ideas on what would be going on. I have posed about this before but I think by doing more research on what my check engine light was on for I think i may have found the issue. Mind you i have only had this car for about 3 weeks and from what I was told it was rebuilt and only had 30k, Chassis has 238k.
2003 Honda Civic EX
Mods:
Headers with no Cat Converter (not legal in my state so theres one issue for me)
Full exhaust
Cold air intake (unsure of brand)
Innovative Performance chip
Stage 3 clutch
My problem is when I am driving the car after its had time to warm up, Approaching a stop light or sign I go into neutral and coast and my car stalls out. I have also noticed even at stop in park with parking brake engaged, just pressing clutch makes RPS go real low and sometimes that alone can make the car stall. sometimes when stalling out it won't restart, and thus needs a jump.
from doing research on what codes my check engine light was throwing off I had a good idea of what my problem was but I want another persons advice.
The following codes were being read:
P1259-VTEC SYSTEM FAILURE (Which the dealer said they fixed of me when I had it in for recent takata airbag recall)
P0135-O2-S1 HEATER
P0141-O2 S2 HEATER FAILURE
MISSING MY B2 O2 SENSOR HARNESS
PLEASE HELP ME!!
Old Jan 1, 2018 | 06:55 PM
toyomatt84's Avatar
Sanji
Have you removed that "performance chip" yet? If not, I'm almost 100% confident its the root of the problem. As I've said before, there's no "performance chip" for the 2001-2005 Civic. That's a scam product, and is usually a resistor in the box reducing the electrical output of a sensor (commonly the MAF or MAP), which forces the ECU to run the WRONG fueling mode. This can cause internal damage, and can actually reduce performance (contrary to what the ad will claim).
Old Jan 3, 2018 | 01:46 PM
holmesnmanny's Avatar
remove the chip, wire back in the o2 sensor, clear the codes
Old Jan 5, 2018 | 07:50 AM
magog45's Avatar
What he said
DGTakeFlight
Jun 26, 2018 12:51 PM
jmwhonda
Jul 11, 2016 05:59 AM
YNG
Aug 29, 2008 05:15 PM
rockybalboa11
Honda Civic (2006 - 2015)
26
Feb 13, 2008 04:38 PM
