Transmission & Drivetrain Gearboxes, Differentials, Clutches
91 Crx Shift Link....
Old Dec 21, 2017 | 05:26 AM
william bonnie's Avatar
Icon5 91 Crx Shift Link....
Morning, My sons friend has a crx and last night we were unable to remove link bolt. so i cut it. now it spins and doesn't come out. tried hammering it out. nothing. Any suggestions please. anything will be a great help. you guys rock.
Old Dec 21, 2017 | 06:31 AM
DumpdEJ6's Avatar
I like the tuna here
Default Re: 91 Crx Shift Link....
Are you referring to where the linkage fits onto the transmission shaft? Because there's not supposed to be a bolt there, there is supposed to be a drift pin/tension pin/bitch pin there.
Old Dec 21, 2017 | 07:24 AM
no where shifter and rod connect. its loose when in gear and very loose in neutral. trying to help this young man.
Old Dec 22, 2017 | 01:26 PM
DumpdEJ6's Avatar
If the shifter has a lot of "slop" in it, it's usually not because of where the shifter connects to the linkage, but where the linkage connects to the transmission. There is supposed to be a drift pin in there, but a lot of people actually replace that with a bolt, which creates side-to-side slop. If you've already cut the bolt at the shifter (trying to drop the linkage down from the shifter?) then I can't think of any reason why it wouldn't come out. Do you have any good pictures of what you're talking about, by chance?
Old Dec 26, 2017 | 06:55 AM
I do not but will show you what im speaking about through a pic from my parts catalog. i work in parts for honda. but want to do it myself. the more i learn the better. I appreciate your help brother.
william bonnie
Dec 19, 2017 10:51 AM
swizz977
Nov 22, 2011 07:34 PM
JDMPR
Sep 21, 2009 06:11 PM
egg_baLLa
24
Aug 19, 2004 08:59 PM
crxzcracer
10
Jun 20, 2004 09:54 PM
