Headliner - Chess Board Blue
I planned this headliner for a few years and finally got around to it. The material is chess board blue. The material is a about 1/16" thick. It was easy to work with being so thick. I used DAP Weldwood Original Contact Cement glue from Home Depot which has a long working time. You can lift the material if needed to correct a wrinkle. The only downside was that the visor plastic attachment swivels had to be pushed in and turned with a hard force to install.
crxforum
Oct 23, 2002 06:32 PM
