Request Assistance: AP1 s2000 stock rom bin file
That's not really a thing. I mean like, you can pull binary data from anything, but there's not much you can do with it unless you're a developer. If you were a developer I kind of doubt you'd be asking such a generalized question.
You can find .kal files for K-Pro equipped or .fpcal files for FlashPro equipped cars. The Hondata vault should have some cals labeled as "stock."
I see what you're up to.
I put 2 & 2 together and see you've been poking around on pgmfi.org too. What mcu does the s2000 ecu use?
I'm concerned that their supported ecu list only has 37805 ecus.
i dont know if it works for sure but i want to try and see what comes out of it.just need an ecu dump from ap1 and send it to them to see if they can map it out and add support for it
OKI something. i forgot.
i just got the kit yesterday and have the bin for KB1 RL . gives me limited access but its better than nothing at all
since he already tuned about 5 RLs with winols and other tools which hondata and ktuner say its impossible...
also support for 04-06 TSX without swapping the ecu
and some other cars as well.
its definitely not as cookie cutter as hondata and ktuner and not a real time programming or datalogging. but its better than nothing
gentek1145
May 11, 2011 04:42 AM
