Transmission & Drivetrain Gearboxes, Differentials, Clutches
Need help clutch confusion
Old Dec 11, 2017 | 04:08 PM
badazchk's Avatar
Default Need help clutch confusion
You can see where something grinded against the metal in a circular motion. But I only found a few metal shavings. Nothing else was in there or fell out.
Springs are intact. I see nothing broken. When I put my finger in the center, it's very loose and wiggles around and is noisy.
I was having problems with car refusing to go into gear. Someone told me that the master slave should be replaced. So I replaced it. Afterwards the car would absolutely refuse to go into any gear unless the car was off. But if I did that and started it while it was in gear, it would lunge forward like I didn't have the clutch peddle pushed. And also constant rattling from clutch area while running with clutch engaged or not. So I bought a new clutch and pulled the motor. This is what I seen.
Old Dec 14, 2017 | 09:23 AM
holmesnmanny's Avatar
Default Re: Need help clutch confusion
are you saying the clutch disk is loose ? nothing should be moving inside when you put your fingers in there
badazchk
Dec 11, 2017 03:45 PM
snzh22
Apr 29, 2008 09:22 AM
old_school_dohcvtec
Oct 4, 2007 09:47 AM
2wheelhunter
Aug 30, 2006 07:32 PM
