EG6 - Code 20? ELD replacement?
Old Dec 11, 2017 | 11:24 AM
XSlor's Avatar
Default EG6 - Code 20? ELD replacement?
Hello HondaTech peeps - new here.
I purchased my first Honda a few months back - an EG6.
The guy that sold it to me said there was some battery issues and replaced said battery before he gave me the car.
After a few months of driving, my car won't start now! Turn key = nothing. I have a check engine light on. I'm pulling a code 20 = ELD? I'm thinking it had something similar to do with the battery.
After reading into this, I found out the ELD is physically inside the fuse box. I spoke to several auto shops and they're telling me to either go to a wrecker or get aftermarket fuse box.
Is there resources on the aftermarket option? Car is already heavily modified, so I figure aftermarket is probably not a bad way to go. I just don't know anything about electrical and I think it's something I don't mind learning and understanding - as long as it's not a high risk to the car!
I've called all the closest wreckers with no luck...
Thoughts?
Old Dec 11, 2017 | 01:36 PM
mk378's Avatar
Default Re: EG6 - Code 20? ELD replacement?
ELD will not prevent starting. Many times a code 20 is spurious and goes away.
Troubleshoot the no-crank conventionally. Assuming the battery is live and the battery connections are secure, the next common problem on manual Civics is breakage of the plastic piece in the clutch pedal arm that presses the clutch safety switch. If the switch is not pressed as it should be when you push the clutch pedal all the way down, starter will not operate.
Old Dec 11, 2017 | 01:46 PM
XSlor's Avatar
Thank you for the feedback! I'll check this out.
Yeah the check engine light came on and a day later car wouldn't start. So I assumed it was that.
I'll report back.
D831SI
Acura TL, RL & ZDX
Nov 27, 2012 11:57 PM
Mr_Si-R
Honda Civic (2006 - 2015)
Dec 5, 2011 06:33 AM
RCJ0227
Acura TL, RL & ZDX
Jul 8, 2010 03:33 PM
Pete_SI
Jul 30, 2005 05:07 PM
