jdm ecu VS usdm ecu
the only difference I'm aware of is the JDM one has a 115mph governor.
assuming you are using them both on an OBDI motor, either will work with the other.
that would sux. i was able to hit 3rd gear in my car now with my jdm ecu (with spoon chip which is causing my problems). i wouldn't wanna get cut at 115mph
The fuel and timing is also more aggressive because they run higher octane over in Japan.
[Modified by satan_srv, 1:03 AM 11/12/2002]
never the less the higher octane does make a difference, like the difference between running 89 versus 92 or 91 octane. it is higher and the japanese gsr and japanese b16a also run more aggressive tables vs the american gsr and del sol ecu.
its only 1 point octane though (93 here in ga), how much of a difference could it make?
also i have a obdI 93 usdm h22a1 p13, in great condition...how much is it worth to you?
